Anyone have this butteryfly?
winger15mk
Post by winger15mk »
Does anyone have an SVG file similar to the butterfly glass name card I have attahced?
Would really appreciate any help.
Ingegard
Re: Anyone have this butteryfly?
Post by Ingegard »
Re: Gorgeous butterfly place card, PLEASE? svg
If you search the forum you will find this.
I did this with the one I found here. Open the file and have a look.
Butterfly place card.scut2
(37.57 KiB) Downloaded 703 times
Windows 10 Scal 2 and 4. Black Cat Cougar
dragonlord666
Post by dragonlord666 »
OK so a quick and dirty trace of that pic gave me this
Butterfly Placecard.svg
(5.02 KiB) Downloaded 1029 times
you might want to play with the nodes/lines a little - the 3 small butterflies are already "cut out" (extracted) from the large one so you'd need to "break apart" to alter those (I did this so it's easier to grab and resize as it's now a single object)
Gaz
Computer:IMac running Mojave
Ingegard
Post by Ingegard »
Very good! One day I will find out how to do that.... ;)
dragonlord666
because the pic is not square on (it's taken at an angle) you have to trace half, then duplicate, flip and union.
then trace the small butterfly and duplicate it and reduce the size, rotate and place in place.
all done with the bezier tool :)
then you just select the large butterfly and the smaller ones and path>exclusion (I used inkscape but in scal it would be back minus front I think)
Gaz
Ingegard
Post by Ingegard »
Oh thank you! :D
dragonlord666
your welcome.
Gaz
