Does anyone have an SVG file similar to the butterfly glass name card I have attahced?
Would really appreciate any help.
Anyone have this butteryfly?
- butterfly.jpg (60.29 KiB) Viewed 17834 times
Re: Anyone have this butteryfly?
Re: Gorgeous butterfly place card, PLEASE? svg
If you search the forum you will find this.
I did this with the one I found here. Open the file and have a look.
- Butterfly place card.scut2
- (37.57 KiB) Downloaded 694 times
- butterfly_glassdecor.png (9.13 KiB) Viewed 17830 times
Windows 10 Scal 2 and 4. Black Cat Cougar
OK so a quick and dirty trace of that pic gave me this
you might want to play with the nodes/lines a little - the 3 small butterflies are already "cut out" (extracted) from the large one so you'd need to "break apart" to alter those (I did this so it's easier to grab and resize as it's now a single object)
Gaz
Gaz
Computer:IMac running Mojave
Very good! One day I will find out how to do that....
because the pic is not square on (it's taken at an angle) you have to trace half, then duplicate, flip and union.
then trace the small butterfly and duplicate it and reduce the size, rotate and place in place.
all done with the bezier tool
then you just select the large butterfly and the smaller ones and path>exclusion (I used inkscape but in scal it would be back minus front I think)
Gaz
Gaz
your welcome.
Gaz
Gaz
