Welding Makes Items not Cut
Faith Art
Post by Faith Art »
when i weld something inside another thing it doesnt cut at all please help!
welcome home4x6a.scut
(100.72 KiB) Downloaded 100 times
Re: Welding Makes Items not Cut
Unfortunatly, everything with weld selected that is inside something else welded will be welded together (solid, no cut lines). The only way to do what you want is to use a shape, a hollow rectangle. Here is a rectangle frame svg for you to use. HTH
frame.svg
(2.35 KiB) Downloaded 75 times
