Please help with removing part?!?
sunnyNP
Post by sunnyNP »
Could someone please help me with removing part of an image in inkscape? It should be easy but I can't remove a black box around an initial I want to use for an engraving. When I select break apart and remove the outer box, the rest of the design turns black. How do I remove just the outer box that I don't want to cut???? When I do a union after removing the outer box, the design remains black. Please help?
B-initial.svg
(7.61 KiB) Downloaded 193 times
talanhart
Re: Please help with removing part?!?
Post by talanhart »
Try this.
sunnyNP
Post by sunnyNP »
thanks so much todd! would you mind telling me how you did it? I know this should be easy but I can't figure it out!!! Thanks again!
talanhart
Post by talanhart »
I just opened the file in Illustrator and deleted the box. I use Illustrator for most of the artwork files I create. Sorry I can't tell you how it would be done in Ink, because I don't have my laptop with me to try.
Picture 1.png (44.5 KiB) Viewed 2256 times
In Inkscape
Click on the node tool (it is the one under the select arrow)
See the nodes at the 4 corners of the black line? Very carefully delete each one. You'll see a lot on wonky stuff going with each delete but after they are all gone the file is fine.
Beautiful graphic by the way.
talanhart
Post by talanhart »
Well that's easy enough!
sunnyNP
Post by sunnyNP »
thanks for your fast responses! Have a great day!
