Hope this question makes sense. I'm looking for a way to cut out only the edges of the paper to make a pretty border on a 12 x 12 sheet. Like the "Mini Monograms" Cricut cartridge, that will cut the 12 x 12 paper to give you a full sheet with a scalloped circle or square edge, but I'm looking for the border to be a graceful florish type of look, kind of like victorian edge scissors. Would like to press "fit to page" on the expression, and get a full sheet with a pretty cut edge.
Any ideas? Thanks--
Denise
Die cutting edges of paper?
Re: Die cutting edges of paper?
The only problem that I see with this is that once you create a fancy-edged frame and then remove the center, you also remove most of the character, and leave the shape looking a lot like a scalloped frame. Regardless, I took a few tries at it. I have not cut them, as I am at work...
One is a torn edge - not exacatly what you wanted.
2 were flourish types that I removed the center detail
The last one is where I left the detail... if I had erased all of the fancy part it would look similar to the one above - sort of scalloped.
Hope this helps.
Enjoy!
Hope this helps.
Enjoy!
- 12x12-cuts.gif (6.66 KiB) Viewed 6656 times
- 12x12 cuts.svg
- (97.58 KiB) Downloaded 583 times
Thanks for sharing the file. I think you did a great job creating them.
Wow! Thanks for taking the time to do this!!! Have had a crazy day and just had a chance to check the board. Will try this soon... totally nutso with life until past the weekend. Very nice of you!
Denise
Denise
Wow, Holly!! I don't know how I missed these before! I am cutting them right now. They are turning out awesome! Thanks!!! Love your files!
Suzy
Thank youuuuuuuuuuuuu!!! very nice
Yes, thank you from me too! Not sure how I missed this either!
These are just lovely....Thanks so much for sharing
Have a great weekend
Thanks so much! I bet we could even scale them down and use them for mounting photos!
Evelyn
Evelyn
Thank you, love the scrolly one.
