Die cutting edges of paper?
DeDe15
Post by DeDe15 »
Hope this question makes sense. I'm looking for a way to cut out only the edges of the paper to make a pretty border on a 12 x 12 sheet. Like the "Mini Monograms" Cricut cartridge, that will cut the 12 x 12 paper to give you a full sheet with a scalloped circle or square edge, but I'm looking for the border to be a graceful florish type of look, kind of like victorian edge scissors. Would like to press "fit to page" on the expression, and get a full sheet with a pretty cut edge.
Any ideas? Thanks--
Denise
hbennett
Re: Die cutting edges of paper?
Post by hbennett »
The only problem that I see with this is that once you create a fancy-edged frame and then remove the center, you also remove most of the character, and leave the shape looking a lot like a scalloped frame. Regardless, I took a few tries at it. I have not cut them, as I am at work... :D
One is a torn edge - not exacatly what you wanted.
2 were flourish types that I removed the center detail
The last one is where I left the detail... if I had erased all of the fancy part it would look similar to the one above - sort of scalloped.
Hope this helps.
Enjoy!
12x12 cuts.svg
(97.58 KiB) Downloaded 583 times
lovemypoodle
Post by lovemypoodle »
Thanks for sharing the file. I think you did a great job creating them.
DeDe15
Post by DeDe15 »
Wow! Thanks for taking the time to do this!!! Have had a crazy day and just had a chance to check the board. Will try this soon... totally nutso with life until past the weekend. Very nice of you!
Denise
scraphappysue
Post by scraphappysue »
Wow, Holly!! I don't know how I missed these before! I am cutting them right now. They are turning out awesome! Thanks!!! Love your files! :D
Suzy
Nelliesil
Post by Nelliesil »
Thank youuuuuuuuuuuuu!!! very nice
kelsie94
Post by kelsie94 »
Yes, thank you from me too! Not sure how I missed this either!
scrappinbykris
Post by scrappinbykris »
These are just lovely....Thanks so much for sharing :D Have a great weekend :)
Check out my blog for free svgs ....Enjoy :) Kris
http://scrappinbykris.blogspot.com/
Evelyn
Post by Evelyn »
Thanks so much! I bet we could even scale them down and use them for mounting photos!
Evelyn
Kim
Post by Kim »
Thank you, love the scrolly one.
