Hi, does anyone have a bass drum that I could have or know where to find one? I'm helping a friend do up goody bags for her daughter's marching band and their theme this year is DRUMatic, hence the need for a bass drum. Unfortunatley, I need it quick Wednesday, 11/7 at the latest (preferably tomorrow, 11/8).
Thanks! Rose
Need help finding a BASS DRUM
Re: Need help finding a BASS DRUM
Here is my try....
Attached is the detailed image I used to create the svg.
the way I would work this file is that I would add the black lines across the "red" part of the drum with a black pen.
Good luck!
Good luck!
- bassdrum2_sample.png (32.54 KiB) Viewed 2039 times
- bassdrum2.svg
- (47.3 KiB) Downloaded 151 times
- basedrum2.png (15.01 KiB) Viewed 2039 times
Thank you so much! I'm not sure how to cut this out. Would I could the whole thing out of three differant colors and then piece it together? Or is there a way to cut three differant layers? Thanks. Again.
The file has three colors, black, white and red.
I thought you could import the svg file, and then cut each layer. The red in whatever your school color may be. And then you have a black and white layer too.
Attached is another option with just two layers, black and white.
The white is a base layer, and the black may be thin too cut, if you are cutting these small, depending on how sharp your blade may be.
- bassdrum3.svg
- (51.08 KiB) Downloaded 157 times
- basedrum3_a.png (18.84 KiB) Viewed 2019 times
- basedrum3.png (19.62 KiB) Viewed 2019 times
EXCELLENT!!! Thank you!
