Need help finding a BASS DRUM
Indygirl
Post by Indygirl »
Hi, does anyone have a bass drum that I could have or know where to find one? I'm helping a friend do up goody bags for her daughter's marching band and their theme this year is DRUMatic, hence the need for a bass drum. Unfortunatley, I need it quick Wednesday, 11/7 at the latest (preferably tomorrow, 11/8).
Thanks! Rose
DogCarbon
Re: Need help finding a BASS DRUM
Post by DogCarbon »
Here is my try....
Attached is the detailed image I used to create the svg.
the way I would work this file is that I would add the black lines across the "red" part of the drum with a black pen.
Good luck!
bassdrum2.svg
(47.3 KiB) Downloaded 151 times
Indygirl
Post by Indygirl »
Thank you so much! I'm not sure how to cut this out. Would I could the whole thing out of three differant colors and then piece it together? Or is there a way to cut three differant layers? Thanks. Again.
DogCarbon
Post by DogCarbon »
The file has three colors, black, white and red.
I thought you could import the svg file, and then cut each layer. The red in whatever your school color may be. And then you have a black and white layer too.
Attached is another option with just two layers, black and white.
The white is a base layer, and the black may be thin too cut, if you are cutting these small, depending on how sharp your blade may be.
bassdrum3.svg
(51.08 KiB) Downloaded 157 times
Rosie0530
Post by Rosie0530 »
Love these. You guys are so good! Thanks. Rosie
EXCELLENT!!! Thank you!
