I need help picturing this file
mrg68
Post by mrg68 »
Hi! Could someone be so kind to cut this file and piece it together. Then take a picture of it and post it for me? When I cut it and piece it, it just looks like I cut it and pieced it together. When you guys do that, your work looks like it was cut in one piece. I can't figure out what I am doing wrong so I can make it look like one piece. I downloaded this file from the internet and it is perfect for what I need.
sailboat cricut.svg
(11.08 KiB) Downloaded 110 times
I am going to make baby announcements for my niece, using a sailboat theme, so I am going to be cutting out ALOT of these.
Thanks for your help!!
DogCarbon
Re: I need help picturing this file
Post by DogCarbon »
i am not sure if this is what you want, but I took the file, and made the sail boat parts on each level in inkscape.
The levels are a base layer, a bottom of boat, the sails and a top sail.
I have attached the revised file... and a picture of the new file colored.
sailboat cricut.png (19.41 KiB) Viewed 1326 times
sailboat cricut.svg
(12.07 KiB) Downloaded 101 times
Just glue your edges down really tight to your paper pieces.. That's all I do.. and use it sparingly..You don't want the paper to show like its wet...
