Hi! Could someone be so kind to cut this file and piece it together. Then take a picture of it and post it for me? When I cut it and piece it, it just looks like I cut it and pieced it together. When you guys do that, your work looks like it was cut in one piece. I can't figure out what I am doing wrong so I can make it look like one piece. I downloaded this file from the internet and it is perfect for what I need.
Thanks for your help!!
I am going to make baby announcements for my niece, using a sailboat theme, so I am going to be cutting out ALOT of these.I need help picturing this file
Re: I need help picturing this file
i am not sure if this is what you want, but I took the file, and made the sail boat parts on each level in inkscape.
The levels are a base layer, a bottom of boat, the sails and a top sail.
I have attached the revised file... and a picture of the new file colored.
- sailboat cricut.png (19.41 KiB) Viewed 1327 times
- sailboat cricut.svg
- (12.07 KiB) Downloaded 101 times
Just glue your edges down really tight to your paper pieces.. That's all I do.. and use it sparingly..You don't want the paper to show like its wet...
