Extra lines in scal
Faith Art
Extra lines in scal
Post by Faith Art »
scal seems to be inserting extra lines.
i made 4x6ribbon3 in inkscape
and 4x6ribbonA in illustrator - the lines dont show up in print preview but do when i cut.
4x6 ribbonA.svg
(96.61 KiB) Downloaded 84 times
4x6ribbon3.svg
(11.45 KiB) Downloaded 72 times
for the one in inkscape i tried the stroke path, path union, path break apart thing but it only seemed to get worse so i uploaded the original file.
thanks
Re: Extra lines in scal
Your images are both made mostly of lines. SCAL requires all images to be closed forms. If you don't have closed forms, SCAL will cut the extra lines. One way you can fix this is to connect each of the end nodes to make the closed shapes. Another way is to select the entire image, make a bitmap copy, trace it, break it apart, and delete the extra pieces. You could also use the paint bucket, but I didn't get good results with that, maybe Firstcut could help you there.
shellieh
Post by shellieh »
I did this one, it had an extra line down the side. try it now.
4x6 ribbonA resampled.svg
4x6 ribbon respampled
(2.74 KiB) Downloaded 76 times
GrammyKrausse
Post by GrammyKrausse »
some of the lines are not connected, or I shoud say they are broken lines. If you color your svg file you'll see where they need the nodes connected.
Grammy
Faith Art
Post by Faith Art »
to shellieh
it still has lines in the preview in scal
to GrammyKrausse if i color it in it wont cut at all. it shows up gray on the print preview.
thanks
It sounds like a lot of steps, but making the bitmap copy and tracing it was the fastest solution. Here are the cleaned up files.
4x6ribbon3.svg
(7.98 KiB) Downloaded 89 times
4x6 ribbonA.svg
(7.21 KiB) Downloaded 77 times
