path start offset missing
kkeeble
Post by kkeeble »
Im trying to change the start of the text that i placed in a circle.. it used to be called path start offset in earlier versions but is missing in scal4 pro. any ideas how to change the start offset now?
craftedge
Site Admin
Re: path start offset missing
Post by craftedge »
With the Type on Path tool selected, the Start Offset is available in the tool options area above the mat.
kkeeble
Post by kkeeble »
But how to you make the text on the bottom of the circle like this...
kkeeble
Post by kkeeble »
The above sample was done in another program
craftedge
Site Admin
Post by craftedge »
If you are using the Type on Path, you would need to select the path and choose Path -> Reverse Path and then type on the path.
Alternatively you could use Object on Path (last example)
viewtopic.php?f=18&t=41013
or the Type on Arch with the Text option set to Inside
