path start offset missing
Im trying to change the start of the text that i placed in a circle.. it used to be called path start offset in earlier versions but is missing in scal4 pro. any ideas how to change the start offset now?
Re: path start offset missing
With the Type on Path tool selected, the Start Offset is available in the tool options area above the mat.
- Craft Edge
http://www.craftedge.com
But how to you make the text on the bottom of the circle like this...
- text.jpg (50.56 KiB) Viewed 4048 times
The above sample was done in another program
If you are using the Type on Path, you would need to select the path and choose Path -> Reverse Path and then type on the path.
Alternatively you could use Object on Path (last example)
viewtopic.php?f=18&t=41013
or the Type on Arch with the Text option set to Inside
- Craft Edge
