Font for numbers
Font for numbers
Can anyone suggest a font for sort of a fancy but easily cut numbers? Thanks
Re: Font for numbers
Hi, I've sorta looked at some of the fonts I have and don't see any. But you could find some that are a little different and add swirls or shapes to enhance them. Might be a fun project.
I think this one has possibilities, it is called FREEBOOTER SCRIPT. I don't know where it got it but it had to be free or I wouldn't have it.
If you want it a little larger you can duplicate it and add a shadow layer at 1.00 and get it nicely large enough to cut.
The answer depends somewhat on how large you are cutting the numbers and the material that you are cutting. I would either use a font manager or go to DaFont and look through the fonts with the sample text set to the numbers you want. Here are some of the fonts that I have that I thought might work for you, but I didn't even make it through the C's.
- font numbers.PNG (53.83 KiB) Viewed 3714 times
THANKS LADIES these will work!!!
