Font for numbers
Share your favorite fonts to use in Sure Cuts A Lot
CMA
Font for numbers
Post by CMA »
Can anyone suggest a font for sort of a fancy but easily cut numbers? Thanks
Re: Font for numbers
Hi, I've sorta looked at some of the fonts I have and don't see any. But you could find some that are a little different and add swirls or shapes to enhance them. Might be a fun project.
I think this one has possibilities, it is called FREEBOOTER SCRIPT. I don't know where it got it but it had to be free or I wouldn't have it. :lol:
If you want it a little larger you can duplicate it and add a shadow layer at 1.00 and get it nicely large enough to cut.
Screen shot 2012-12-05 at 10.02.37 AM.png (14.37 KiB) Viewed 3670 times
The answer depends somewhat on how large you are cutting the numbers and the material that you are cutting. I would either use a font manager or go to DaFont and look through the fonts with the sample text set to the numbers you want. Here are some of the fonts that I have that I thought might work for you, but I didn't even make it through the C's. ;)
font numbers.PNG (53.83 KiB) Viewed 3668 times
CMA
Post by CMA »
THANKS LADIES these will work!!!
