Hi
Been trying hard to convert this image into a svg, could anyone please help?
Help make a svg
Help make a svg
- butterfly.jpg (64.75 KiB) Viewed 3443 times
Re: Help make a svg
here you go. download the file again just did a adjustment and i did cut it out no problems with peices falling out that were not supposed to.
- butterfly.svg
- (24.56 KiB) Downloaded 265 times
Re: Help make a svg
Thanks Rachell. Just tried to cut this and some of the fancy edge is not joined up even though the image shows it all together.
Have you cut this out?
Re: Help make a svg
which machine are you using ? are you sure your blade is not to far out and possible cutting it where it shouldn't be.stephie911 wrote:Thanks Rachell. Just tried to cut this and some of the fancy edge is not joined up even though the image shows it all together.
Re: Help make a svg
I'm not sure if you still this, but I traced it anyway. There's a couple of versions for you to choose from. HTH
- Lacy_butterfly_rs.svg
- (126.06 KiB) Downloaded 272 times
Re: Help make a svg
Rachelle, I'm using my new expression machine. What do you mean by the blade to far out?
Re: Help make a svg
thanks for your input, much appreciated. will let you know how I get on tomorrow cutting this, need to go bed now,been a long day.
Re: Help make a svg
Cuts great, thanks all for the help
Re: Help make a svg
I'm attaching another version of the butterfly with both sides lacy. This was an idea was inspired by Sandy's cut-out of this butterfly on the Re-Nu post. Thank Sandy!
viewtopic.php?f=6&t=27643
- Lacy_Butterfly2_rs.svg
- (125.35 KiB) Downloaded 255 times
