Help make a svg
Requests for finding a Font or Shape to use in Sure Cuts A Lot
stephie911
Help make a svg
Post by stephie911 »
Hi
Been trying hard to convert this image into a svg, could anyone please help?
Rachell
Re: Help make a svg
Post by Rachell »
here you go. download the file again just did a adjustment and i did cut it out no problems with peices falling out that were not supposed to.
butterfly.svg
(24.56 KiB) Downloaded 265 times
stephie911
Re: Help make a svg
Thanks Rachell. Just tried to cut this and some of the fancy edge is not joined up even though the image shows it all together.
Have you cut this out?
Rachell
Re: Help make a svg
Post by Rachell »
stephie911 wrote:Thanks Rachell. Just tried to cut this and some of the fancy edge is not joined up even though the image shows it all together.
which machine are you using ? are you sure your blade is not to far out and possible cutting it where it shouldn't be.
pastda3
Re: Help make a svg
Post by pastda3 »
I'm not sure if you still this, but I traced it anyway. There's a couple of versions for you to choose from. HTH
Lacy_butterfly_rs.svg
(126.06 KiB) Downloaded 272 times
stephie911
Re: Help make a svg
Rachelle, I'm using my new expression machine. What do you mean by the blade to far out?
stephie911
Re: Help make a svg
thanks for your input, much appreciated. will let you know how I get on tomorrow cutting this, need to go bed now,been a long day.
stephie911
Re: Help make a svg
Cuts great, thanks all for the help
pastda3
Re: Help make a svg
Post by pastda3 »
I'm attaching another version of the butterfly with both sides lacy. This was an idea was inspired by Sandy's cut-out of this butterfly on the Re-Nu post. Thank Sandy! :)
viewtopic.php?f=6&t=27643
Lacy_Butterfly2_rs.svg
(125.35 KiB) Downloaded 255 times
