folded castle card
raewyn64
folded castle card
Post by raewyn64 »
Ok here we go.
I have attached (I hope) two .scut files. One has all the 4 castles on a 12x24 cutting mat and them all welded together so can just be cut.
The other one has all 4 castles on a 12x12 mat. The first two are welded together and the last two are welded together and I have put a small tab at the end of the second castle so they can be joined together after cut.
If you want each one separately then just un-weld them and cut each one - attach a tab to each one if you want.
Hopefully also is an image from Inkscape of how the 4 layers would sort of look when all cut out.
As I said in another post, I have not yet cut this so no guarantees. Each castle is 4 inches long. I had to make a few changes from the original image supplied by bdhardy as curves were a little tricky so I stuck to straight lines so I could get everything symetrical.
Let me know how it goes. I would love to see any made if the scut files work.
Raewyn
fold castle1.scut
(8 KiB) Downloaded 370 times
fold castle.scut
(7.41 KiB) Downloaded 377 times
folding castle.JPG (10.85 KiB) Viewed 3771 times
bdhardy
Re: folded castle card
Post by bdhardy »
Thank you so much! It looks perfect! I am VERY excited to try it!
dhoffm02
Post by dhoffm02 »
That was great..The front of the castle is a little too tall, blocking the tower. If you just "shorten" it in scal(2 1/2 inches look right), it comes out great. Your drawing is correct, but castle 1's peak cuts higher than shown. I'm going to make a larger one, and try a book! I had made a "paper" version last night of my own pattern that I was trying to input into scal, and you did it first, saving me lots of time. THanks a million!
lesliefolks
Post by lesliefolks »
awesome!! thanks for your time!!! and sharing!!!
