Ok here we go.
I have attached (I hope) two .scut files. One has all the 4 castles on a 12x24 cutting mat and them all welded together so can just be cut.
The other one has all 4 castles on a 12x12 mat. The first two are welded together and the last two are welded together and I have put a small tab at the end of the second castle so they can be joined together after cut.
If you want each one separately then just un-weld them and cut each one - attach a tab to each one if you want.
Hopefully also is an image from Inkscape of how the 4 layers would sort of look when all cut out.
As I said in another post, I have not yet cut this so no guarantees. Each castle is 4 inches long. I had to make a few changes from the original image supplied by bdhardy as curves were a little tricky so I stuck to straight lines so I could get everything symetrical.
Let me know how it goes. I would love to see any made if the scut files work.
Raewyn
folded castle card
folded castle card
- fold castle1.scut
- (8 KiB) Downloaded 371 times
- fold castle.scut
- (7.41 KiB) Downloaded 378 times
- folding castle.JPG (10.85 KiB) Viewed 3775 times
Re: folded castle card
Thank you so much! It looks perfect! I am VERY excited to try it!
That was great..The front of the castle is a little too tall, blocking the tower. If you just "shorten" it in scal(2 1/2 inches look right), it comes out great. Your drawing is correct, but castle 1's peak cuts higher than shown. I'm going to make a larger one, and try a book! I had made a "paper" version last night of my own pattern that I was trying to input into scal, and you did it first, saving me lots of time. THanks a million!
awesome!! thanks for your time!!! and sharing!!!
