Nanibird is a site with a cute little bird paper toy. There are many different "skins" using the same template. I downloaded one of the PDFs and traced it into an SVG cut file. Since most of the PDFs use the same template with different graphics, you can import the PDF into the SVG with Inkscape, line things up, print the PDF and then open the SVG in SCAL to cut. The new calibration feature in SCAL helps make the cuts nicely accurate.
Because the PDFs contain both bitmap and vector objects, you can't import the PDF directly into SCAL. You could try saving the PDF as a PNG and then importing the image to SCAL so that you could print & cut from SCAL.
If all of that sounds too complicated, you can just cut the birdie out of paper and enjoy.
- nanibird.jpg (88.74 KiB) Viewed 2131 times
EDIT: I messed up the SVG template. Somehow there were three copies of all the cut lines. I removed the extras.
And P.S. Saving the texture as PNG and importing it into SCAL for alignment and printing works great.
