I haven't used SCAL in a while . . .
phokan56
Post by phokan56 »
. . . so I know this is something I SHOULD remember but I just don't.
After I bring a SVG file into SCAL, how to I "ungroup" so I can move the "pieces" around on my mat to group items being cut from the same piece of cardstock? I'm just drawing a blank!
Thanks for your help.
Patti H.
wvcathy
Re: I haven't used SCAL in a while . . .
Post by wvcathy »
I believe you select it > Options > Ungroup > or Break apart -- BUT if you break apart it will break apart everything. For example the center of the letter "A"
I am at work so can't look at it right now - but I am pretty sure these are the steps
Hope it helps,
Cathy
If the file was created with layers or groups you can use Object/Ungroup to move the layers independently. If everything is on one layer you will need to use Object/Break apart. If you need to use Break apart, it does break Everything apart so you will need to be careful if anything has internal cuts. HTH
