installation problems - USB driver issue
wvsasha
Post by wvsasha »
I have a Cricut expression machine and running on laptop with Windows XP - bought & downloaded SCAL and installed. Opened program - it tells me I don't have the USB driver installed. Followed directions to get it downloaded - unzipped.
The video tutorial on installing the tutorial does not match the screens I have.
When I plug in the CE to the laptop - the computer tells me the hardware is installed and ready for me. I check the hardware device list but the "USB serial converter" is not listed however there is something listed called "USB high speed serial converter" listed but not at the bottom of the list as the video says.
So I go back to SCAL = same error message of USB driver not installed.
I"m on about hour 3 trying to make this work. I need help.
Thanks.
Deloris
Re: installation problems - USB driver issue
Post by Deloris »
Open your SCAL program, click the Help tab at the top of the screen, then select Install USB drivers from the drop down menu.
Hope that helps
wvsasha
Post by wvsasha »
Excellent - ok - now we're making progress.
I got the driver installed.
But now I can't get the firm ware updated. Help?
THe only way I've found is the download the DS software but it's trial version download site is down.
Deloris
Post by Deloris »
wvsasha wrote:Excellent - ok - now we're making progress.
Some Cricut machines come with the correct firmware version. What does it show in the window of your Cricut when you turn it on?
wvsasha
Post by wvsasha »
2.0
Deloris
Post by Deloris »
wvsasha wrote:2.0
Here's the info from the Craftedge website on what firmware you would need for your Cricut machine.
Info on how to update is under #3 at this link:
http://www.craftedge.com/support/faq/faq_general.html
wvsasha
Post by wvsasha »
Deloris wrote:
wvsasha wrote:2.0
Yes - thanks - I've read that - and thus my problem....the mirror site to download DS in order to get update is down. If anyone has the trial version file and would be willing to send it to me - I would greatly appreciate it.
wvsasha[at]gmail.com
wvsasha
Post by wvsasha »
SOmeone sent me a link to a different download site so I'm working on getting DS installed so I can update my firmware so I can play with SCAL!!
Woot!
Thanks Deloris for the help!
