I have a Cricut expression machine and running on laptop with Windows XP - bought & downloaded SCAL and installed. Opened program - it tells me I don't have the USB driver installed. Followed directions to get it downloaded - unzipped.
The video tutorial on installing the tutorial does not match the screens I have.
When I plug in the CE to the laptop - the computer tells me the hardware is installed and ready for me. I check the hardware device list but the "USB serial converter" is not listed however there is something listed called "USB high speed serial converter" listed but not at the bottom of the list as the video says.
So I go back to SCAL = same error message of USB driver not installed.
I"m on about hour 3 trying to make this work. I need help.
Thanks.
installation problems - USB driver issue
Re: installation problems - USB driver issue
Open your SCAL program, click the Help tab at the top of the screen, then select Install USB drivers from the drop down menu.
Hope that helps
Hope that helps
Excellent - ok - now we're making progress.
I got the driver installed.
But now I can't get the firm ware updated. Help?
THe only way I've found is the download the DS software but it's trial version download site is down.
Some Cricut machines come with the correct firmware version. What does it show in the window of your Cricut when you turn it on?wvsasha wrote:Excellent - ok - now we're making progress.
Here's the info from the Craftedge website on what firmware you would need for your Cricut machine.wvsasha wrote:2.0
Info on how to update is under #3 at this link:
http://www.craftedge.com/support/faq/faq_general.html
- Capture.JPG (80.35 KiB) Viewed 3884 times
Yes - thanks - I've read that - and thus my problem....the mirror site to download DS in order to get update is down. If anyone has the trial version file and would be willing to send it to me - I would greatly appreciate it.Deloris wrote:Here's the info from the Craftedge website on what firmware you would need for your Cricut machine.wvsasha wrote:2.0
wvsasha[at]gmail.com
SOmeone sent me a link to a different download site so I'm working on getting DS installed so I can update my firmware so I can play with SCAL!!
Woot!
Thanks Deloris for the help!
Woot!
