Attached is my svg tutorial on how I broke apart a large vinyl quote that was about 50" long to fit on a mat and how to line it up easier on the wall.
Thanks Todd, not that Todd, but Talanhart!
This file is not optimized for cutting as I had to simply the text parts to get the file size under the 256K.
I will post the cutting file too, without all the instructions.
How to break apart Large Vinyl Cuts to fit on a mat
- DogCarbon_final.svg
- cutting file
- (162.68 KiB) Downloaded 472 times
- DogCarbon.svg
- instructions:
- (193.91 KiB) Downloaded 353 times
Re: How to break apart Large Vinyl Cuts to fit on a mat
Thank you for these instructions. I d/l them and will file for future reference.
I tried to download to view the file and instruction, but am unable to open. I am running SCAL3, but should still be able to open an svg. Can you help? Thanks!
Cricut Expression, Windows 7 Ultimate (64 bit), SCAL 2.029
Silhouette Cameo, Windows 7 Ultimate (64 bit), SCAL 3.018
tomorrow I will have more time to check out what the problem is with the files. SVG files should be able to IMPORTED to SCAL3 with out a problem.
the tut i did not get but the verse I did. thank you. gonna go see if i can see why. is it supposed to be svg form (tutorial)
Theresa
ps, i opened it in inkscape and can get the tut.
Theresa
yes, if you bring the instruction into inkscape, you can read them there... but there are 5 steps I used in ink.
Attached are the five images:
- DogCarbon1.png (15.34 KiB) Viewed 4278 times
- DogCarbon2.png (35.59 KiB) Viewed 4278 times
- DogCarbon3.png (26.06 KiB) Viewed 4278 times
Continued steps:
- DogCarbon4.png (29.05 KiB) Viewed 4278 times
- DogCarbon5.png (46.65 KiB) Viewed 4278 times
Thank you so much!!!
