How to break apart Large Vinyl Cuts to fit on a mat
DogCarbon
Post by DogCarbon »
Attached is my svg tutorial on how I broke apart a large vinyl quote that was about 50" long to fit on a mat and how to line it up easier on the wall.
Thanks Todd, not that Todd, but Talanhart!
This file is not optimized for cutting as I had to simply the text parts to get the file size under the 256K.
I will post the cutting file too, without all the instructions.
DogCarbon_final.svg
cutting file
(162.68 KiB) Downloaded 475 times
DogCarbon.svg
instructions:
(193.91 KiB) Downloaded 356 times
DogCarbon
Re: How to break apart Large Vinyl Cuts to fit on a mat
Post by DogCarbon »
bump
pastda3
Post by pastda3 »
Thank you for these instructions. I d/l them and will file for future reference. :)
pengyou
Post by pengyou »
I tried to download to view the file and instruction, but am unable to open. I am running SCAL3, but should still be able to open an svg. Can you help? Thanks!
Cricut Expression, Windows 7 Ultimate (64 bit), SCAL 2.029
Silhouette Cameo, Windows 7 Ultimate (64 bit), SCAL 3.018
DogCarbon
Post by DogCarbon »
tomorrow I will have more time to check out what the problem is with the files. SVG files should be able to IMPORTED to SCAL3 with out a problem.
TheresaTT
Post by TheresaTT »
the tut i did not get but the verse I did. thank you. gonna go see if i can see why. is it supposed to be svg form (tutorial)
Theresa
TheresaTT
Post by TheresaTT »
ps, i opened it in inkscape and can get the tut.
Theresa
DogCarbon
Post by DogCarbon »
yes, if you bring the instruction into inkscape, you can read them there... but there are 5 steps I used in ink.
Attached are the five images:
DogCarbon
Post by DogCarbon »
Continued steps:
pengyou
Post by pengyou »
Thank you so much!!!
