Pointsettia
scrappindeb
Pointsettia
Post by scrappindeb »
I layered patterned paper and added gold ribbon. I stamped a pointsettia with embossing ink. Then heat embossed gold embossing powder. I then painted on pearlescent inks. Then stickled the edges. The picture isn't that good tho.
Scrappindeb
Re: Pointsettia
WOWZERS...you are just toooooooooooo good!
scrappindeb
Re: Pointsettia
gj1 wrote:WOWZERS...you are just toooooooooooo good!
You're making me blush! Thank you so much for your comments, they are always so nice!
Scrappindeb
sstehman
Re: Pointsettia
Post by sstehman »
Well, have never tried embossing yet, but I just bought a heat gun and a set of those multi-colored ink pads that you can pop out. Was told to used pigment ink and then put clear embossing powder on it and used the heat gun. But I see you used embossing ink (no clue what it is). I still have so much to learn and you are so talented with your designs and techniques. Haven't had time to try the method I described, but will soon. Maybe you can just tell me if you ever did heat embossing this way and what embossing inks are?
Don't laugh because I really don't know.
Re: Pointsettia
I have seen this done with a clear embossing ink pad and you wet the stamp and stamp the paper and then sprinkle on powders with colors in them and then heat them up and they look COOOOOL! I have also heard that even ink from a printer on the printed page if done on BEST for heaviest can then be sprinkled with the powder and heated up with the gun. You are going to be showing us some more neat stuff now Sandy. Have fun!
scrappindeb
Re: Pointsettia
sstehman wrote:Well, have never tried embossing yet, but I just bought a heat gun and a set of those multi-colored ink pads that you can pop out. Was told to used pigment ink and then put clear embossing powder on it and used the heat gun. But I see you used embossing ink (no clue what it is). I still have so much to learn and you are so talented with your designs and techniques. Haven't had time to try the method I described, but will soon. Maybe you can just tell me if you ever did heat embossing this way and what embossing inks are?
There are embossing inks, I have quite a few of them. You can then just heat them. This card in particular I used clear embossing pad (the refill bottle has clear liquid or ink) and then I sprinkled the gold embossing powder over it and it just sticks to what you emboss. Then you heat it and the gold melts onto it. I also use just clear embossing powder which makes it like a lacquer when heated with the heat gun. The embossing inks I buy most are Versa Color inks. I also like to use Color Box Chalk Ink, not really to emboss, I just love the texture of those inks and they are great for color blending. (And, I would never laugh. We all start there and grow. I stamped for many years and made cards before I started scrapbooking and then into the cutters, etc.
Good luck with your heat gun and embossing. ;)
Scrappindeb
Re: Pointsettia
Thanks for the info. I never did this...but if I ever extend my supplies list..this is something I would like because just look at the GREAT things that can be done.
scrappindeb
Re: Pointsettia
gj1 wrote:Thanks for the info. I never did this...but if I ever extend my supplies list..this is something I would like because just look at the GREAT things that can be done.
That's true, and there is even more techniques, etc. than I do! It's ENDLESS!!!! But I love it!
Scrappindeb
