Hi I have Inkscape but have never had the time to learn it at all (someday). I have been manually cutting this envelope and was wondering if it could be made into a SVG file?
I have uploaded my drawing of it. Can anyone make this? The Fold line are just for my benefit they do not need to be perforated or anything.
Melinda
Can someone create a SVG for me?
- the 1/2 circle is not centered in the drawing but I would need it centered in the file.
- evelope drawing.jpg (97.13 KiB) Viewed 3064 times
Re: Can someone create a SVG for me?
I attached an scal file, but it does not have the 1/2 circle cut out. could not figure out how to do that with scal. maybe you could cut the envelope & use a circle punch to cut the 1/2 circle out.
Here it is, this was really easy.
Just three rectangles aligned and welded with the half circle removed.
- envelope.svg
- (2.63 KiB) Downloaded 180 times
here it is
- full size template_0001.jpg (86.3 KiB) Viewed 3045 times
Thank you both! Heather, is there any way to get it to import smaller? When I import it is so large that I can't get it scale down because the either the move corner or the shrink arrows are off the page. Does that make sense?
thanks
Melinda
thanks
Melinda
forgive me I figured it out. DUH use the nudge arrows to move it around (Blonde Moments)
If you have SCAL1, set the default height to 4.5 inches before importing. If you have SCAL2, it should import at 4.5x11.5 if your SCAL2 import dpi is set for Inkscape.
You can also select the imported image, then resize with the properties window. HTH
Heather, It cut beautifully! This will make my life so so much easier, I can't thank you enough!
I wonder what else I can automate, If I would just take the time to learn this program!
Thanks for the tip- I found and change how it comes in and it worked perfectly. thank again
