Program Closes
Polocksgal
Program Closes
Post by Polocksgal »
I have downloaded Inkscape. and i have first started by inporting a shape to use to practice with. but when i finally get the shape into Inkscape, the program closes :oops: . Any ideas & help would be great.
Vicki
Proud Military Mom
Re: Program Closes
What type of file are you working with? Svg, image, font, other?
Polocksgal
Re: Program Closes
I have tried SVG's, JPG's, and GIFs so far, is there a certain type of file i need to add to it first to start with?
Vicki
Proud Military Mom
Re: Program Closes
You would open the svg files, and either import or paste the others. I don't know why you are having it close on you, other than it sometimes does crash (save your work often). I have an older laptop, so sometimes if I have too many files open it takes too much memory and freezes up. If it is consistently closing, tell step by step what you are doing before it crashes.
Polocksgal
Re: Program Closes
I open Inkscape, click on file, click on import, browse to where i want to find my picture, click on selected picture, and then it closes.
Vicki
Proud Military Mom
Re: Program Closes
I couldn't get Inkscape to crash with any of the files I tried importing. It wouldn't import scut or psd, but they didn't crash it either. Have you been able to open any of the svg files from this forum?
deliacm
Re: Program Closes
Post by deliacm »
I've had Inkscape do this many times and it's always related to one of the files I have saved in the folder I'm trying to open. Have you added any downloaded files to the folder you are trying to access lately? If you don't have too many files in the folder, I would suggest moving the files one by one until you find the culprit. I find this too often when I'm trying to access my "JPGs for Conversion" folder, but has also often occured with some bad svg's that I've downloaded.
I would bet this is your issue. Good luck finding the bad guy.
Christina
“I do that which I cannot do in order that I may learn how to do it.” ~Picasso
Tingha Treasures
Re: Program Closes
Post by Tingha Treasures »
okay just a thought on downloaded files I have often found my say they are blocked when Ive right clicked and gone to properties of the file. Im using WINXP service pack 3 might be worth while checking.
9-03-2009 2-49-02 PM.png (29.18 KiB) Viewed 3204 times
