Help text in a shape
dolanqt
Post by dolanqt »
I think I used to know what to do but now that I have been learning more I am actually having trouble. I am trying to put text in a shape and its not coming out right in SCAL. How do I fix this?
This is just an example butr no somethig I will be using so I will need steps. I tried using difference but I think I am missing a step.
Thanks in advance.
Courtney
test.scut
(11.67 KiB) Downloaded 115 times
test.svg
(6.13 KiB) Downloaded 117 times
AnointedHands
Re: Help text in a shape
Post by AnointedHands »
If you are using INK .47, you need to select the shape and then Path>Union. I did that and that fixed the problem I saw when I opened the svg file. I no longer have .46 installed so I can't go thru the steps to correct that version.
Since you are using SCAL2, I can't see the file.
HTH
Althea
Anointedhands your file didn't work in Scal2.. the l's were missing and the center of the "a" wasn't connected.. Anyhow.. I have inkscape .47 and redid it. Opened in SCAL2 and now it works... You use object/difference... here you go...
dolanqt
Post by dolanqt »
I knew it was something silly I was forgetting. Problem solved, thanks!
