Tech Question: Which font in the workspace
ebstauffer
Post by ebstauffer »
I'm trying to get SCAL2 to work in linux. So far pretty good luck. I can use the product, save SCUTs, import SVGs. Still cant actually cut to the cricut but I know the reason and am working on that. One small cosmetci issue is that wine is not selecting the correct font for the workspace. To illustrate:
Workspace Font Selection
If I can determine actual font that's being used I can ensure that it is available to wine. If any tech type people are reading any insight would be appreciated.
my_key
Re: Tech Question: Which font in the workspace
Post by my_key »
Run "wine executablename.exe" (found in .wine/drive_c/Program\ Files/Craft\ Edge) from the command line. It should give some output about a missing font or some font function not being implemented. Google the string that seems to be causing the problem, usually you can find a solution. If it's a wine bug report the bug, it will get fixed. If you get the program working please put it in the AppDB on winehq.
My wife has recently ordered a cricut of ebay. When it gets here I will help testing.
Good luck.
Michael
lylyacfey
Post by lylyacfey »
Hi!
Has anybody been able to cut in Linux so far? Any info would be appreciated.
