Trying to get some help if possible.
00castle
Post by 00castle »
I am working on a design that has many smaller circles inside a bigger design. I need the smaller circles inside to remain the same size. Is there a way to resize the entire design to make it bigger but leave the circles the same size, without having to go in and manually resize the circles.
Re: Trying to get some help if possible.
Yes. Select the design and go to Object>Break Apart. Now you can independently select the outside and resize as desired. Then Select All and apply Object>Merge.
The only issue is that you didn't mentioned spacing. Were you wanting the circles to stay in place (which happens with the method I just mentioned) or were you want them to move with the resizing so they are in the same relative locations as they were with respect to the outside, but just not change sizes? I can help with that, as well.
