How do I import my svg image into Scal and have it remain the size it was created in?
The largest gerber daisy is 2.45" yet Scal keeps cutting it at 3.25"?
Thanks.
Keeping image the same size when importing
- Gerber Daisy lg petals.svg
- (11.28 KiB) Downloaded 150 times
Re: Keeping image the same size when importing
I didn't do the math, but I would guess that you haven't changed your svg default to Inkscape in SCAL2? Below is an image from a different post, but do you see the 2nd drop down box, "SVG DPI"? Unless you use AI, make sure that is set to Inkscape. You get to this window through the Edit/Preferences menu. HTH
