Detect-i-bear
AnointedHands
Detect-i-bear
Post by AnointedHands »
Stuck on the magnifying glass thing.
This is a teddy bear from my clip art collection. I am posting it so you guys can see it...I know you won't download it because it might be copyright infringements (just kidding).
OK, now that this is said.......
Detect-a-bear 0404.svg
(55.23 KiB) Downloaded 489 times
Elsie
Re: Detect-i-bear
Post by Elsie »
thanks for sharing, Els
kkrewtea
Re: Detect-i-bear
Post by kkrewtea »
He's cute! You didn't actually ADD the magnifying glass to his had did you????
Shirl
sboz
Re: Detect-i-bear
Post by sboz »
Annointedhands,
Question for you: I have downloaded the .svg file. I want to do a increase the black background just a tad to create a litte more of a black base. I've tried selecting the black element and then using "dynamic edge" in Inkscape - but I don't get any discernable difference. What am I not doing correctly?
Shari
AnointedHands
Re: Detect-i-bear
sboz wrote:Annointedhands,
Shari
I am not sure what dynamic edge is. I have never used that function. If you want to make the blackout larger, just enlarge it by the arrows. If you hold down CTRL while moving the corner arrows, it will be proportional. In the new version of Inkscape, I noticed a lock so you can use that to do proportional scaling.
Be careful the layers fit once you do your scaling. This bear doesn't have a lot of white space as others do but when layering, you need to keep the pieces scaled to fit or any white spaces might be lost. For instance, the white dot on the bear is highlights for his eyes. If you make the blackout disproportionate to the layers, who knows where the white spot will be when you finish. You might want to make the layers smaller first. You can always work with it in Inkscape, size it and then import it into SCAL.
AnointedHands
Re: Detect-i-bear
kkrewtea wrote:He's cute! You didn't actually ADD the magnifying glass to his had did you????
The magnifying glass was already in his hand...I guess I should have named him Sherlock Bear.
talanhart
Re: Detect-i-bear
Post by talanhart »
Another great file that I found and I didn't need a magnifying glass.
TOASTER
Re: Detect-i-bear
Post by TOASTER »
Adorable little guy!
Toaster
SCAL 2 , SCAL 3, Windows 10
hkvalerio
Re: Detect-i-bear
Post by hkvalerio »
Apparently 127 people didn't care about copyright infringement. :lol:
Heather
