3” x 3” Note card box (Splitcoaststampers Tutorial)
Craigg64
Post by Craigg64 »
Hi
Someone requested one of these http://www.splitcoaststampers.com/resou ... tecardbox/
So here is the svg
Enjoy :D
cheers
Craig
3x3 tote box.svg
(11.7 KiB) Downloaded 890 times
3x3 tote box.png (78.85 KiB) Viewed 5647 times
Cheers
Craig
cad
Re: 3” x 3” Note card box (Splitcoaststampers Tutorial)
Post by cad »
perfecto!
TFS,
Cathy
Check out a new scrapbooking/cardmaking tool made by a small town girl!
www.thefreezeframe.com
newbiecrafternc
Post by newbiecrafternc »
TFS, cannot wait to try this out!!
Craigg64
Post by Craigg64 »
newbiecrafternc wrote:TFS, cannot wait to try this out!!
PM sent. Hopefully that helps :)
Cheers
Craig
newbiecrafternc
Craig, thanks for the instructions... they were spot on. Any idea on what size to cut the box?
Craigg64
Post by Craigg64 »
HI
If you are using SCAL 1 set your font size to 11.5" then import the svg. All the pieces will cut the correct size as per the instructions on Splitcoaststampers.
If using SCAL 2 the file should import at the correct size. Again that should be 11.5" for all 3 pieces.
Hope that helps
Cheers
Craig
Cheers
Craig
LiveLaughScrap
Post by LiveLaughScrap »
Thank You so much for this file.
Do you happen to know how many cards & envies it will hold?
Lori
Lori
LIVELAUGHSCRAP
A PLACE FOR SHARED CREATIVITY
http://livelaughscrap-leedle.blogspot.com
Taffy
Post by Taffy »
thanks for sharing.. I can't wait to try this wheni get home.. :)
