Converted pdf-need help with svg please
Tingha Treasures
Post by Tingha Treasures »
I converted a pdf file to svg in Inkscape saved as a plain svg and it looks okay BUT when I preview in SCAL its all over the place. I think its the straight cutting lines that I know SCAL doesnt like. :)
Could someone be so kind to point me the right direction to correct this.
Thanks in advance
Tingha
Reason: Copyright violation
Re: Converted pdf-need help with svg please
The file has both groups and open lines, both of which cause problems. You have three options.
1. The paint bucket tool
2. Ungroup, increase the stroke width, make a bitmap copy, trace the bitmap, break apart, delete the outside line
3. Ungroup, increase the stroke width, Path/Stroke to path, Path/Union, etc. This option doesn't work well here since some of the lines aren't touching. HTH
Tingha Treasures
thanks Heather I thought you may give me the answer! :D
I will try again
Tingha Treasures
okay its a bit better but the dreaded double lines.
I tend to get to this stage and give up! Anymore suggestions/help appreciated. :D
You need to either connect the open line, or re-trace with a higher threshold. You also have dots inside your lines - a higher trace threshold takes care of this.
flower pot.png (30.89 KiB) Viewed 3448 times
Tingha Treasures
thanks for the help I gave up and printed and cut it by hand! :(
butrcup1221
Post by butrcup1221 »
I have had the same problem with the lines being all over the place. It looks great in inkscape, but not in SCAL. I found that combning the paths fixes the problem.
scrpbooklady
Post by scrpbooklady »
Here is the file cleaned up in case you need it in future!
Tingha Treasures
thanks very much the project that uses this is at http://www.angelslanding.com/stamps-cra ... erpot.html
