Using Inkscape to resize photos or create images of svg file
This works well for images, screen shots, and svg files.
To use this for svg's select all of the parts you want included in the exported image, then continue from step 2.
To use this for screen shots, after step 2, draw a rectangle over the portion you want to keep. Select the screen shot and the rectangle, then from the menu, Object/Clip/Set.
export bitmap1.png (218.2 KiB) Viewed 3461 times
export bitmap2.png (234.83 KiB) Viewed 3461 times
Re: Using Inkscape to resize photos or create images of svg file
Nicely done!
lesliefolks
Post by lesliefolks »
Heather thanks so much for doing this!!!!!
TOASTER
Post by TOASTER »
Since I am new to Inkscape : Is this an easier way to send your file to SCAL? If not, I'm not sure when to use it. Thanks for your help.
Toaster
SCAL 2 , SCAL 3, Windows 10
firstcut
Post by firstcut »
Toaster,
That's a good question, but this doesn't have anything to do with SCAL, per se. Some people use this procedure to "take pictures" of their svgs so the image shows up when they are searching for things. (A bmp version of the same title will appear next to the svg version so the bmp image serves as a proxy for the svg)
This same technique of exporting a bitmap gives a way you can use Inkscape instead of having to open another program to ready photos and screen shots to post on message boards and that kind of thing.
TOASTER
Post by TOASTER »
Kay,
Thanks for the clarification. I'm learning here and there with all of the mb's help how to use Inkscape. At this point in my education I am still a newbie and I am amazed when I am able to import a piece of clipart and eventually cut it out. It usually takes quite a bit of time and many un-do's. So far I have managed to make 3 (yes 3) things!
Toaster
swirliepants
Post by swirliepants »
thanks!
