Please help with removing part?!?
Posted: Fri May 08, 2009 7:02 am
by sunnyNP
Could someone please help me with removing part of an image in inkscape? It should be easy but I can't remove a black box around an initial I want to use for an engraving. When I select break apart and remove the outer box, the rest of the design turns black. How do I remove just the outer box that I don't want to cut???? When I do a union after removing the outer box, the design remains black. Please help?
Re: Please help with removing part?!?
Posted: Fri May 08, 2009 7:21 am
by talanhart
Try this.
Posted: Fri May 08, 2009 9:42 am
by sunnyNP
thanks so much todd! would you mind telling me how you did it? I know this should be easy but I can't figure it out!!! Thanks again!
Posted: Fri May 08, 2009 9:46 am
by talanhart
I just opened the file in Illustrator and deleted the box. I use Illustrator for most of the artwork files I create. Sorry I can't tell you how it would be done in Ink, because I don't have my laptop with me to try.
Posted: Fri May 08, 2009 9:56 am
- Picture 1.png (44.5 KiB) Viewed 2259 times
In Inkscape
Click on the node tool (it is the one under the select arrow)
See the nodes at the 4 corners of the black line? Very carefully delete each one. You'll see a lot on wonky stuff going with each delete but after they are all gone the file is fine.
Beautiful graphic by the way.
Posted: Fri May 08, 2009 10:03 am
by talanhart
Well that's easy enough!
by sunnyNP
thanks for your fast responses! Have a great day!
