I have a problem even my husband can't figure out.
When I go to save an svg file from somewhere on the internet, I right click it to save as (context menu opens) and then I click save as it opens my window, I choose the folder I want it to go in, but instead of it having a button that says save; it says open. So I can't save an svg. If I do this for any other type of image it says 'save image as' (contect menu) and there is a save button showing.
Help me please!
HELP saving Svg files
Re: HELP saving Svg files
I am not sure about it but what happens if you select Open? Does it open it in Inkscape ok? And then can you save it in Inkscape and then import it into SCAL and it appear ok?
Raewyn
Raewyn
Are you using Internet Explorer? I think it is because you are actually downloading zip files. If you select open folder it will show where it is saved or you can just close the window.
What happens when you try to download an svg from this forum?
