line in SCAL not Inkscape
there is a line on top of my frame that i cant get rid of, and only shows up in SCAL
Re: line in SCAL not Inkscape
The extra lines all around the frame are because it is made up of sections that aren't connected. Since they are lines and not shapes, you can't use Path/union. The easiest way to fix it is to select them all, Path/stroke to path. Then Path/Union. Now you have an extra line, so Path/break apart, delete the inner line. When I imported it into SCAL, there was still one extra line at the top. Couldn't find a reason for it in Ink, so copied and pasted your image into a new file, saved it. Now it looks OK in SCAL.
- 4x6frame2b.svg
- (5.13 KiB) Downloaded 67 times
Most likely has something to do with none of your exterior curvy lines are connected to each other. Not for sure though. Might try anointed hands she is the best at solving problem. To start with I would connect the outer lines and make them as one. Not for sure if they will cut unless they are.
Grammy
Grammy
wow! thank you! it looks great!
