Update Available
Createinspain
Update Available
Post by Createinspain »
SCAL5 is now up to V5.030
I have only just downloaded it so I have no idea which bugs have been fixed...
Edit - not the one to fix the auto changing of the left too setting sadly...
Re: Update Available
Thanks for reporting! I know that it was reported on FB that the Despeckle option in the Trace Image window was crashing 5.029 so that might be one that got fixed. Sorry your issue is still there. :(
Createinspain
Yes, the despeckle is reportedly fixed. There is an update to the update notes on the download page thingy...
Sadly, not only is my issue not fixed, but another introduced. If I have a few objects on the mat to cut, it appears that unless I use WYSIWYG it does not cut them in their relative positions.....!! (EVEN WHEN GROUPED)
:evil:
Whoa! That's a huge one. Are you saying everything gets shifted to the origin for cutting? As if Nesting has been applied? Does the Preview window also indicate this? I'll test it out myself after breakfast.
It's not affecting my Skycuts but, for sure, the cut mode is specific to the cutter based on when I was beta testing with all of the various KNK models.
Createinspain
No the preview pane was normal. Not sure what logic it was applying to positioning but I have NEVER ever had a problem like that before! I checked it wasn't the machine with a mat issue, because on WYSIWYG it cut perfectly....
I sent Brandon an email with the file and screen shot and a photo of the result when cut......
Okay. Definitely post if you find out what's up with that one. Very bizarre.
