Trying to cut a shadow layer
gearhead1167
Post by gearhead1167 »
Hi all. I'm using a Roland GX-24 cutter with Sure Cuts A Lot Pro 5. I'm trying to cut simple numbers with 2 shadow layers. If I cut just a single layer number I have no problem, the machine cuts fine. If i add a shadow layer the head of the cutter moves like its going to cut and freezes. I'm new to all of this. any help out there? Thank you.
Re: Trying to cut a shadow layer
I should be able to help you with this, but I'll need a lot more details and also see your cut file, which you can email to me at sandy.mccauley@gmail.com
For starters, I assume you're cutting each layer separately... Are you hiding/showing layers on the Layers Panel to accomplish this or are you using the Cut by Color feature in the Cut Settings window?
