SCAL4/pro will no more export to PLT-format
Snijderke
Post by Snijderke »
Hi, since a few days, my SCAL4/pro wil not export to a PLT-format. It is that format that I need most of all. I tried with different files: all the same : " no data", if I try to import in my Laser-software. Who can help me ?
Thanks in advance.
Greetings from Belgium.
Re: SCAL4/pro will no more export to PLT-format
I want you to try again but start a new file and ONLY have a single simple shape, like a circle. See if that works. If it does, then there's something about the file you're exporting that's causing the issue. One initial thought is this: does the project you're trying to export have a raster image present, such as an imported JPG or PNG image?
