Silhouette Cameo 3
lorieverhart
Silhouette Cameo 3
Post by lorieverhart »
I have been a long time MTC user and am a creature of habit. Very scary to move into the world of SCAL, but I am EXCITED. Is SCAL compatible with Cameo 3?
Thank you and I look forward to learning a lot from this group.
Re: Silhouette Portrait
Yes! Both the Portrait and Portrait 2 are listed in the cutter menu where you select which cutter you'll be using.
Here's a link to the SCAL5 user manual that I wrote:
https://www.iloveknk.com/0um/SCAL5/SCAL ... Manual.pdf
And you might also find this useful since you're a long time MTC owner. It will help you find equivalent functions in SCAL that were using in MTC:
https://www.iloveknk.com/Support/Tutori ... nology.pdf
Yes, SCAL5 is compatible with the Cameo 3 and even the new Cameo 4.
lorieverhart
SandyMcC wrote:Yes, SCAL5 is compatible with the Cameo 3 and even the new Cameo 4.
Thank you :)
lorieverhart
SandyMcC wrote:Yes! Both the Portrait and Portrait 2 are listed in the cutter menu where you select which cutter you'll be using.
Thank you!
