connect i-Craft Cutter plotter w/ Adobe Illustration CS6
alyzamarie_24
Post by alyzamarie_24 »
I wanna use my Adobe Illustration in i-Craft Cutter Plotter but I don't know how to connect it. :( Any help please? :D :D :D
Re: connect i-Craft Cutter plotter w/ Adobe Illustration CS6
You would need to find a GCC user forum to find out if Adobe Illustrator has a plugin you can install for the GCC iCraft model. This forum is devoted to owners of Sure Cuts A Lot software which WILL cut to your iCraft but it requires purchasing a license. You would be able to import .AI files into Sure Cuts A Lot for cutting so keep it in mind if there is no direct way to cut from Illustrator to your cutter. The link for SCAL5 is here:
alyzamarie_24
SandyMcC wrote:You would need to find a GCC user forum to find out if Adobe Illustrator has a plugin you can install for the GCC iCraft model. This forum is devoted to owners of Sure Cuts A Lot software which WILL cut to your iCraft but it requires purchasing a license. You would be able to import .AI files into Sure Cuts A Lot for cutting so keep it in mind if there is no direct way to cut from Illustrator to your cutter. The link for SCAL5 is here:
:D :D Ok thanks a lot! ^^
