SCAL 4 cutting problem
I have been SCAL 4 with a graphtec cutter for almost 2 years now with no problems. It looks like after an update to SCAL 4 just a couple weeks ago something has gone wrong. Now often when a send a cut to the cutter everything is shifted to one side or another just a small amout and it falls outside of the cutting area so the edges do not get cut. The attached image shows where the cut stopped, skipped a short distance and started cutting again. This normally happens if the file is larger then the cut area of the material but in my case it is smaller. I have contacted support about this almost 2 weeks ago with no reply yet. Has anyone else had this problem?
- IMG_20181003_160224752.png (103.08 KiB) Viewed 2931 times
Re: SCAL 4 cutting problem
Can you post screenshots of your main window with the shape(s) and then the Cut Settings window?
Here are the pictures.
- post.jpg (1.18 MiB) Viewed 2903 times
Here is something interesting. I had the install file for 4.069. I uninstalled 4.075 and installed 4.069 and have had no problems with my cuts. The problem started after one of the last updates. I sure looks like a software issue.
I'll get this reported to the developer of SCAL.
