typing in a paragraph
RayRay
Post by RayRay »
Does SCAL5 have the option to type in a paragraph style or do I have to do each line separate? I cant see how to do it if it does....
Ray
Re: typing in a paragraph
I'm not 100% sure if I fully understand your expectations but you can just start typing the text and then manually pressing the Enter or Return key and then you'll be on the next line and you can continue typing. Here's what I'm referring to:
If you're expecting it to automatically go to a new line when it reaches, say, the right side border of the Cutting Mat, then no... it doesn't do that.
RayRay
Post by RayRay »
typically when I type and want to go to start another line and pressed enter it would not go to a new line it would just stop typing in that layer? field? whatever you wanna call it.....so I would have to do another line and then line them up manually....BUT that was in SCAL3...
When I upgrades to SCAL5 recently I assumed it was going to do the same thing...but after reading your response i checked and it works fine in SCAL5....
didn't know that changed with the version changes......I used 3 even though I had 4.....probably because it was what I was used to and don't like changes.....except this one
You're welcome! And glad you decided to update to version 5. There are a LOT of new features and changes, even compared to 4. Here's a list I put together:
http://www.iloveknk.com/wp-content/uplo ... atures.pdf
