How to Install Upgrade from SCAL V4 to SCAL V5
shazcart
Post by shazcart »
Hi there. I'm new to the Forum & just purchased the upgrade from SCAL V4 to V5. Is there any rules I should follow when installing the upgrade or do I just install over the previous version. I've tried to find some info on how to install the upgrade correctly but have had no luck & have run out of time to look.
Re: How to Install Upgrade from SCAL V4 to SCAL V5
Actually, SCAL5 will install into it's own folder which is really nice because it gives you the chance to go back and open SCAL4 in case you think there are any problems with 5. As a tester this was VERY convenient for me. Note that 4 and 5 share the same library and a few other custom things. But if you did any calibration for your cutter such as a sizing calibration or print and cut calibrations you will most likely need to input those numbers directly into SCAL 5.
If you have more questions or need help with anything, please also post if you are on a Mac or PC and which cutter you use for cutting. Thanks!
Sandy
