Stencil Bridge SCAL4
primhp
Post by primhp »
I am trying to change the size of the stencil bridge. I go up to the box above the mat and change the size but it does not effect that actual size on the mat. I need to make the stencil bridge smaller than 0.100 inches. I keep trying but am having no luck. The default size is too large for my projects, in most cases. Any ideas?
Re: Stencil Bridge SCAL4
Did you try actually typing in a new size instead of using the up/down arrows on the setting? I was able to type in, for example, 0.05 and 0.03 and it worked.
primhp
Post by primhp »
Yes, that is the only way I can try to make it smaller. When I use the arrow keys it only goes down to 0.100. When I type the numbers 0.050, it changes but on the mat, there is no size difference.
I played around with it and what I found is that after you type in a new value, press the Enter/Return key on your keyboard. Then it should work. When I failed to do that, I got the same size bridge, even though the option showed the new size.
primhp
Post by primhp »
That worked! Thank you so much!
You're welcome!
