Ok I know this is confusing. Ever since I upgraded to Windows 10 what is happening is that I have my MAIN image on the screen that I want to cut. BUT if I select it there appears an outline around it of the same image that is about 2/3rds the size of the original, and that is the size that it cuts. It makes it VERY hard for placement when you aren't sure if it will overlap or now.
HELP!
Sample attached
Outline of image is larger than image on grid.
- Sample of Image ghost
- Sample.jpg (662.36 KiB) Viewed 3242 times
Re: Outline of image is larger than image on grid.
How many layers are showing in your layers list? it appears that the outline image, is larger than the original. Perhaps if you delete that image and try again it will help. I you want to post the file I'll take a look.
