I have some problems with the "Cut settings" dialog. I'm using a Silver Bullet Pro cutter and SCAL4.
I do the following:
1. Create custom "Holder" for my engraving Tool. (This actually works as intended)
2. Set Offset, pressure and so on correctly.
3. Click the "+" next to "Preset to save
4. Set name to "Press Paper".
5. Do 1-4 again with a knife Tool, save as "Cut paper"
... do some drawing in the program, click "Cutter" to open dialog again, and here comes the problem...
6. Select my newly saved Preset "Press Paper"
7. Preset now shows "Press Paper" for ~0.5 second, but then goes back to "<Custom Preset>"
8. Holder, offset and overcut aren't changed to correct values.
9. I now have to select the correct holder manually.
I have made 7 custom presets and two of them works, but the others do as I have explained.
Am I doing something wrong or is it something you could fix?
Jorgen
SCAL4, Custom cut settings doesn't work properly (PC)
Re: SCAL4, Custom cut settings doesn't work properly (PC)
Looks like a bug in the Silver Bullet plugin. When I try the same thing using the Maxx Air, my new preset name remains selected.
Thank you for your answer
Do you know if I have to report this anywhere or does the developer keep an eye on this forum?
Aha - I should probably post it in the "Bug" category
